MPS2+ with OpenOCD
Is it possible to use MPS2+ with OpenOCD and GDB ?
If so, can you please provide config files for OpenOCD ?
Thank you!
  • Hi,
    now I managed to get it work. More by trial and error then by "knowing what I am doing". But anyhow, it seems to work. But keep in mind that the provided script is surely not optimal.
    Make  the following config file called, say "MPS2.cfg":
    # Main file for MPS2+
    set TARGETNAME MPS2
    set CPUTAPID 0x2ba01477
    interface cmsis-dap
    transport select swd
    swd newdap $TARGETNAME cpu -irlen 4 -expected-id $CPUTAPID
    target create $TARGETNAME.cpu cortex_m -chain-position $TARGETNAME.cpu
    $TARGETNAME.cpu configure -event gdb-attach { halt }
    adapter_khz 1000
    # delays on reset lines
    adapter_nsrst_delay 200
    start openocd in a terminal:
    $ sudo openocd -f MPS2.cfg
    start gdb for ARM in another terminal:
    $ arm-none-eabi-gdb
    in the arm shell  connect to the opencod:
    (gdb)  target remote localhost:3333
    in the openocd terminal you should see some text like this one
    Info : accepting 'gdb' connection on tcp/3333
    target halted due to debug-request, current mode: Thread
Reply Children
No Data
