Run CM3 hex image in Modelsim
is there some guide which shows how to run a Keil hex mage for Cortex M3 in Modelsim?
To be more specific, I want to run an interactive simulation in Modelsim of my Cortex M3 design and associated software  to analyse  timings of CPU instructions and bus accesses
  • Hi there,
    In your Keil MDK project, in the user setting
    Add a command to execute after the build (you might want to change the output filename):
    $K\ARM\ARMCC\BIN\fromelf.exe #L --vhx --8x1 --output hello.hex
    The output file is a list of bytes.
    In your verilog design, you need an AHB ROM model in the simulation testbench. The ROM model can read the hex file using:
      reg    [7:0]  rom_data[0:65535];
    initial
      $readmemh("hello.hex", rom_data);
    regards,
    Joseph
