c++ virtual function override problem
recently i write a c++ code and  have a problem with using virtual function
this is a code,
class Base {
publc :
    virtual ~Base() {}
    virtual void Set (void) = 0; // pure virutal fuunction
class Derived : public Base
public:
    int m_nTest;
    virtual void Set (void) { m_nTest = 10; }
// make global object here !!
Derived gstDerived;
int main (void)
    Base * pstBase  = &gstDerived;
    pstBase->Set();  // -> this is a problem !!!!
if i am using normal function override instead virtual method override, perfectly fine,
but when i am using virtual function, looks like linker can not find overried function, (derived Set())
according to assembly code,
1. get gstDerived address
2.  get data by reference m_nTest member variable ( it initialized to zero at the begining)  as a result get code data from 0x4 address
3. branch with code memory data (i.e., 0xE5000005)
4. prefetch abort
what am i missing to using virtual function. ?
please help me !!!
