Hi,I am a beginner in kernel porting. I am trying to port Linux kernel (version- 4.9.22) on Custom SoC (cpu = arm1176jzfs based) for custom evaluation Board. I am having ARM Prime cell pl011 UART in my SoC. And it is physically mapped to 0x5800_1000 address. While i am trying to use it as Debug UART, kernel is asking for its virtual Address. How should i configure this option.i.e: -> Kernel low-level debugging functions -> kernel low-level debugging port (Kernel low-level debugging on via ARM Ltd PL01x Primecell UART) (0x58001000) Physical base address of debug UART (??) Virtual base address of debug UART
Thanks,
Vivek T.
Hi Matt,
VIC translation fault got resolved. From your suggestion I have gone through other drivers in the kernel, I have incorporated a small piece of code using ioremap() to obtain a virtual address. Looks like now the VIC is initialized and I am able to see the Peripheral ID while booting. Below is the code I have incorporated into my IRQ init function
{void __iomem *vic_base; Int i =0; for(i = 0; i<2; i++) { if (!request_mem_region(bbsoc_vic[i].start, VIC_SIZE, "Vic")) { pr_err("Vic_%d Request mem region failed.\n", i); return –1; } vic_base = ioremap(bbsoc_vic[i].start, VIC_SIZE); if(!vic_base) { pr_err("VIC_%d : ioremap failed...\n\r", i); release_mem_region(bbsoc_vic[i].start, VIC_SIZE); return –1; } If (I == 0) vic_init(vic_base, 0, BBSOC_VIC0_IRQ_MASK, 0); If(I == 1) vic_init(vic_base, 32, BBSOC_VIC0_IRQ_MASK, 0);}
With this, my issue got resolved. and I am unsure about the uart virtual address, Parallelly I need to work on other issues too. Will get back to you once I found anything. Thanks for helping me, Matt.
Vivek
