Unable to run code in optimization level O1, O2 and O3 in DS-5
Hi all,
I am able to run code in optimization level - O0 in DS-5 and outputs also matched with reference outputs, but the same code is not working in other optimization levels - O1, O2 and O3 in DS-5, it is simply exiting from program.
typedef short Word16;
typedef struct student
       Word16  x;
       Word16  y;
}stu;
void inputs_read( stu *st_fx)
          st_fx->x= 0;
          st_fx->y= -1;
This code is not working in DS-5.  when i am trying to run, at this point program execution stopped in DS-5.
I tried debugging the code in -O1, -O2 ,I found it is not able to find some structure variables with data type short int , other variables from the same structure with same data types are working fine. I didn't understand the reason.
I added a printf() statement in between these two structure variables , with this code is working fine. But i am not getting whether the issue is related to structure variables or alignment or with other.
          st_fx->x= 0;
          printf("%d\n", st_fx->x);
          st_fx->y= -1;
with this printf() statement code is working fine.
Can anyone please guide me on this. I blocked at this point, please help me on this.
Thanks in advance,
Divya.
