How to run AArch32 code in DS-5 AArch64?
I installed DS-5 64-bit version in windows, but i received 32-bit code which is running on AArch32 without any issue , and it's not running on my machine with AArch64 DS-5, is there any setting which i can do to run the same code without any changes? or do i need to do any code changes in 32-bit code to run on 64-bit DS-5?
Thanks,
Divya.
