IoT boards which are compatible with wireless vibration sensors
I need suggestion for IoT boards which will easily compatible with gateway receiver which is receiving the data from Wireless vibration sensors and at same time also need to connect the sensor data with google sheets.
As newbie I need to know from where I should start to make this solution work
