Dynamic memory allocation and UART
Former Member
Former Member
Hi friends, I came across a problem with my UART communication.My codes are below.
if I use
rx_buffer = (uint8_t*)calloc(3,sizeof(uint8_t));
HAL_UART_Receive_IT(&huart1,&rx_data,1);  and rx_buffer = (uint8_t*)realloc(rx_buffer,sizeof(uint8_t));
program works , but if I use these codes
rx_buffer = (uint8_t*)calloc(10,sizeof(uint8_t));
it doesn't work,I changed 10 instead of 3 in calloc. As much as I remembered stm32f103 stop to work after the first sending data.probably hardfault.I couldn't debug because of limited USB input.
#include "main.h"
#include "stm32f1xx_hal.h"
#include "usart.h"
#include "gpio.h"
#include "stdlib.h"
void SystemClock_Config(void);
static void MX_NVIC_Init(void);
void Clear_Buffer(void);
uint8_t rx_data=0;
uint8_t *rx_buffer;
uint8_t rx_index=0;
uint8_t dataReady=0;
uint8_t length=0;
int main(void)
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_USART1_UART_Init();
MX_USART2_UART_Init();
MX_NVIC_Init();
while (1)
Clear_Buffer();
if(dataReady)
dataReady = 0;
for(int i=0;i<length;i++) rx_buffer[i] = NULL;
free(rx_buffer);
//Bu interrupt fonksiyonuna ait prototip zaten oldugundan ayrica tanimlamaya gerek yoktur
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
if(huart->Instance == USART1)
HAL_GPIO_TogglePin(GPIOC,GPIO_PIN_13);
if(rx_data != 13)
rx_buffer[rx_index++] = rx_data;
else
length = strlen(rx_buffer);
//Gönder
HAL_UART_Transmit(&huart1,rx_buffer,length,1000);
dataReady = 1;
rx_index = 0;
