printf in opencl kernel not work
I try to printf logs within the kernel of opencl, but it does not work. And then I try the example code of  <program guide of opencl>, it does not work too. What I did wrong? please give me some suggestions, the example code are as follows:
#include <stdio.h>
#include <CL/cl.h>
#include <CL/cl_ext.h>
const char *opencl =
"__kernel void hello() \n"
"{\n"
" printf(\"Hello, World!\\n\");\n"
"}\n";
void callback( const char *buffer, unsigned int length, size_t final, void *user_data)
printf("%.*s", length, buffer);
int main()
cl_platform_id platform;
cl_device_id device;
cl_context context;
cl_context_properties context_properties[] =
CL_PRINTF_CALLBACK_ARM, (cl_context_properties)callback,
CL_PRINTF_BUFFERSIZE_ARM, 0x100000,
CL_CONTEXT_PLATFORM, 0,
0
cl_command_queue queue;
cl_program program;
cl_kernel kernel;
clGetPlatformIDs(1, &platform, NULL);
context_properties[5] = (cl_context_properties)platform;
clGetDeviceIDs(platform, CL_DEVICE_TYPE_GPU, 1, &device, NULL);
context = clCreateContext(context_properties, 1, &device, NULL, NULL, NULL);
queue = clCreateCommandQueue(context, device, 0, NULL);
program = clCreateProgramWithSource(context, 1, &opencl, NULL, NULL);
kernel = clCreateKernel(program, "hello", NULL);
clEnqueueTask(queue, kernel, 0, NULL, NULL);
clFinish(queue);
clReleaseKernel(kernel);
clReleaseProgram(program);
clReleaseCommandQueue(queue);
clReleaseContext(context);
return 0;
  • Hi ericlew,
    Which GPU you use ?
    does GPU support OpenCL 1.2 and above version ?
    In OpenCL 1.1 printf will work through OpenCL extension, for ARM GPU you should use cl_arm_printf:
    "\n#ifdef cl_arm_printf\n"
    "#pragma OPENCL EXTENSION cl_arm_printf: enable\n"
    "#endif\n
    "{\n"
    "}\n";
    OpenCL 1.2 and above supports printf in kernels without extensions.
