OpenCL driver issue with Samsung Chromebook
I had an issue with the OpenCL Driver on my Chomebook.
I followed ARM's instruction and successfully boot into Linux. However, I got an error message said that libxcb-dri2.so missing. After install libxcb-dri2.0-dev, I can compile Mali OpenCL SDK sample codes. But they won't be executed correctly under X11 or via fbdev. I past error message below. Any suggestion? Thanks.
> ./hello_world_opencl
OpenCL error: CL_OUT_OF_HOST_MEMORY
Creating an OpenCL context failed. common.cpp:248
Failed to create an OpenCL context. hello_world_opencl.cpp:39
> ldd hello_world_opencl
        libOpenCL.so => /opt/mali/fbdev/libOpenCL.so (0x76efc000)
        libstdc++.so.6 => /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 (0x76e4a000)
        libgcc_s.so.1 => /lib/arm-linux-gnueabihf/libgcc_s.so.1 (0x76e39000)
        libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76d55000)
        /lib/ld-linux-armhf.so.3 (0x76f07000)
        libmali.so => /opt/mali/fbdev/libmali.so (0x76304000)
        libpthread.so.0 => /lib/arm-linux-gnueabihf/libpthread.so.0 (0x762e9000)
        libm.so.6 => /lib/arm-linux-gnueabihf/libm.so.6 (0x7627e000)
        librt.so.1 => /lib/arm-linux-gnueabihf/librt.so.1 (0x76270000)
        libdl.so.2 => /lib/arm-linux-gnueabihf/libdl.so.2 (0x76265000)
