Connect with Custom Board (am5726 SoC) using DStream
Hi
I am using custom board (am5726) with DStream and unable to connect (RVC file is attached)
<?xml version="1.0"?>
<?RVConfigUtility MajorVersion = "0" MinorVersion = "0" PatchVersion = "0"?>
<RVConfigUtility>
   <redistributable value="true"/>
   <RVConfigModule>
      <?RVConfig DLL_NAME = "connection" MajorVersion = "1" MinorVersion = "0" PatchVersion = "0" Expanded = "true" Active = "false" Enabled = "true" UserLabel = ""?>
      <ScanChainNames Type = "Str">?</ScanChainNames>
      <ConnectionManager Type = "User" Inherited = "true">0x0820CBE4</ConnectionManager>
      <TemplateManager Type = "User" Inherited = "true">0x0820CC00</TemplateManager>
      <BrokerCoreList Type = "User" Inherited = "true">0x0820CC34</BrokerCoreList>
      <PlatformName Type = "Str" Inherited = "true"/>
      <NoOfScanChains Type = "Int32" Inherited = "true">1</NoOfScanChains>
      <FirmwareVersion Type = "Str">4.13.0</FirmwareVersion>
      <ConnectionName Type = "Str" Inherited = "true"/>
      <ChildModuleName Type = "Str" Inherited = "true">Devices</ChildModuleName>
      <RVConfigModule>
         <?RVConfig DLL_NAME = "scanchain" Expanded = "true" Active = "true" Enabled = "true" UserLabel = "" MajorVersion = "1" MinorVersion = "1" PatchVersion = "0"?>
         <TemplateName Type = "Str" Inherited = "true">/real-ice/jtag-templates/arm/cs_memap/V1.0</TemplateName>
         <ChildModuleName Type = "Str" Inherited = "true">CSMEMAP</ChildModuleName>
         <Class Type = "Str"/>
         <CanonicalName Type = "Str"/>
         <DeviceOptions Type = "Str" Inherited = "true"></DeviceOptions>
         <IRLength Type = "Str" Inherited = "true">0</IRLength>
         <ModuleName Type = "Str">Devices</ModuleName>
         <TAPPosUpdateInProgress Type = "Str" Inherited = "true">FALSE</TAPPosUpdateInProgress>
         <CurrentTAPPos Type = "Str" Inherited = "true">_21_</CurrentTAPPos>
         <NewTAPPos Type = "Str" Inherited = "true">_21_</NewTAPPos>
         <RVConfigModule>
            <?RVConfig DLL_NAME = "dynamiccore" Expanded = "true" Active = "false" Enabled = "true" UserLabel = "" MajorVersion = "1" MinorVersion = "0" PatchVersion = "0"?>
            <TemplateName Type = "Str"></TemplateName>
            <ModuleName Type = "Str">UNKNOWN</ModuleName>
            <IRLength Type = "Str">6</IRLength>
            <DeviceOptions Type = "Str"></DeviceOptions>
         </RVConfigModule>
         <RVConfigModule>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cs_arm_dap/V1.0</TemplateName>
            <ModuleName Type = "Str">ARMCS-DP</ModuleName>
            <IRLength Type = "Str">4</IRLength>
            <CanonicalName Type = "Str">ARMCS-DP</CanonicalName>
            <Class Type = "Str">DebugPort</Class>
            <DataList Type = "Branch">
               <DataListUID Type = "User">0x00000004</DataListUID>
               <MEMORY_ACCESS_AP Type = "Str">0x00000000</MEMORY_ACCESS_AP>
            </DataList>
            <ExtendedTypeInfo Type = "Branch"/>
         </RVConfigModule>
         <RVConfigModule>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cortexm4/V1.0</TemplateName>
            <ModuleName Type = "Str">Cortex-M4</ModuleName>
            <IRLength Type = "Str">0</IRLength>
            <DeviceOptions Type = "Str">ETM,FPv4-SP</DeviceOptions>
            <CanonicalName Type = "Str">Cortex-M4</CanonicalName>
            <Class Type = "Str">CoreExecutable</Class>
               <DataListUID Type = "User">0x00000005</DataListUID>
               <CORESIGHT_AP_INDEX Type = "Str">0x00000000</CORESIGHT_AP_INDEX>
               <JTAG_TIMEOUTS_ENABLED Type = "Str">True</JTAG_TIMEOUTS_ENABLED>
               <ALLOW_EXECUTION_WITHOUT_T_BIT Type = "Str">False</ALLOW_EXECUTION_WITHOUT_T_BIT>
               <POST_RESET_STATE Type = "Str">1</POST_RESET_STATE>
               <CTI_SYNCH_START Type = "Str">False</CTI_SYNCH_START>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
               <DataListUID Type = "User">0x00000006</DataListUID>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
               <DataListUID Type = "User">0x00000007</DataListUID>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
               <DataListUID Type = "User">0x00000008</DataListUID>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cortexa15/V1.0</TemplateName>
            <ModuleName Type = "Str">Cortex-A15</ModuleName>
            <DeviceOptions Type = "Str">ETM</DeviceOptions>
            <CanonicalName Type = "Str">Cortex-A15</CanonicalName>
               <DataListUID Type = "User">0x00000009</DataListUID>
               <CORESIGHT_AP_INDEX Type = "Str">0x00000001</CORESIGHT_AP_INDEX>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x80000000</CORESIGHT_BASE_ADDRESS>
               <CODESEQ_ENABLED Type = "Str">False</CODESEQ_ENABLED>
               <CODESEQ_CODE_ADDR Type = "Str">0x0007FF80</CODESEQ_CODE_ADDR>
               <CODESEQ_CODE_SIZE Type = "Str">0x80</CODESEQ_CODE_SIZE>
               <CODESEQ_TIMEOUT Type = "Str">100</CODESEQ_TIMEOUT>
               <BYPASS_MEMPROT_IN_DBG Type = "Str">True</BYPASS_MEMPROT_IN_DBG>
               <CLEAR_BRKHW Type = "Str">True</CLEAR_BRKHW>
               <IGNORE_START_DEBUG_PRIV_FAIL Type = "Str">False</IGNORE_START_DEBUG_PRIV_FAIL>
               <BYPASS_DEVICE_ID_CHECK Type = "Str">False</BYPASS_DEVICE_ID_CHECK>
               <DEBUG_ACCEL Type = "Str">0</DEBUG_ACCEL>
               <ALLOW_BACKGROUND_PROC Type = "Str">True</ALLOW_BACKGROUND_PROC>
               <ALLOW_DBGNOPWRDWN Type = "Str">True</ALLOW_DBGNOPWRDWN>
               <CHECK_DSCR_DBGEN Type = "Str">True</CHECK_DSCR_DBGEN>
               <OSLOCK_OVERRIDE Type = "Str">0</OSLOCK_OVERRIDE>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cs_pmu/V1.0</TemplateName>
            <ModuleName Type = "Str">CSPMU</ModuleName>
            <CanonicalName Type = "Str">CSPMU</CanonicalName>
            <Class Type = "Str">TraceSource</Class>
               <DataListUID Type = "User">0x0000000A</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x80001000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
               <DataListUID Type = "User">0x0000000B</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x80002000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
               <DataListUID Type = "User">0x0000000C</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x80003000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cs_cti/V1.0</TemplateName>
            <ModuleName Type = "Str">CSCTI</ModuleName>
            <CanonicalName Type = "Str">CSCTI</CanonicalName>
            <Class Type = "Str">Link</Class>
               <DataListUID Type = "User">0x0000000D</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x80008000</CORESIGHT_BASE_ADDRESS>
               <SYNCH_START_ENABLE Type = "Str">false</SYNCH_START_ENABLE>
               <SYNCH_START_CHANNEL Type = "Str">0</SYNCH_START_CHANNEL>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
               <DataListUID Type = "User">0x0000000E</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x80009000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cs_ptm/V1.0</TemplateName>
            <ModuleName Type = "Str">CSPTM</ModuleName>
            <CanonicalName Type = "Str">CSPTM</CanonicalName>
               <DataListUID Type = "User">0x0000000F</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x8000C000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
               <DataListUID Type = "User">0x00000010</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x8000D000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cs_tf/V1.0</TemplateName>
            <ModuleName Type = "Str">CSTFunnel</ModuleName>
            <CanonicalName Type = "Str">CSTFunnel</CanonicalName>
               <DataListUID Type = "User">0x00000011</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x80018000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cs_stm/V1.0</TemplateName>
            <ModuleName Type = "Str">CSSTM</ModuleName>
            <CanonicalName Type = "Str">CSSTM</CanonicalName>
               <DataListUID Type = "User">0x00000012</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x8001A000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
               <DataListUID Type = "User">0x00000013</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x8001C000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cs_tpiu/V1.0</TemplateName>
            <ModuleName Type = "Str">CSTPIU</ModuleName>
            <CanonicalName Type = "Str">CSTPIU</CanonicalName>
            <Class Type = "Str">TraceSink</Class>
               <DataListUID Type = "User">0x00000014</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x80023000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
               <DataListUID Type = "User">0x00000015</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x80024000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cs_tmc/V1.0</TemplateName>
            <ModuleName Type = "Str">CSTMC</ModuleName>
            <CanonicalName Type = "Str">CSTMC</CanonicalName>
               <DataListUID Type = "User">0x00000016</DataListUID>
               <CORESIGHT_BASE_ADDRESS Type = "Str">0x80027000</CORESIGHT_BASE_ADDRESS>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
            <?RVConfig DLL_NAME = "dynamiccore" Expanded = "true" Active = "false" Enabled = "true" UserLabel = ""?>
            <TemplateName Type = "Str">/real-ice/jtag-templates/arm/cs_memap/V1.0</TemplateName>
            <ModuleName Type = "Str">CSMEMAP</ModuleName>
            <CanonicalName Type = "Str">CSMEMAP</CanonicalName>
            <Class Type = "Str">AccessPort</Class>
               <DataListUID Type = "User">0x00000019</DataListUID>
            </DataList>
         </RVConfigModule>
         <RVConfigModule>
               <DataListUID Type = "User">0x0000001A</DataListUID>
            </DataList>
         </RVConfigModule>
            <DataListUID Type = "User">0x00000002</DataListUID>
            <ClockType Type = "Int32">7</ClockType>
            <ClockSpeed Type = "Str">10000000</ClockSpeed>
            <OtherSpeed Type = "Str">10.000 MHz</OtherSpeed>
            <Tap_Count Type = "UInt32">22</Tap_Count>
            <Tap_0 Type = "Branch">
               <DataListUID Type = "User">0x00000003</DataListUID>
               <CoreName Type = "Str"></CoreName>
               <FamilyName Type = "Str"></FamilyName>
               <DllName Type = "Str">dynamiccore</DllName>
               <TemplateVersion Type = "Str"></TemplateVersion>
               <DllVersion Type = "Str"></DllVersion>
               <Description Type = "Str">UNKNOWN</Description>
               <DeviceID Type = "Str">0x1B85202F</DeviceID>
               <Manufacturer Type = "Str">Texas Instruments</Manufacturer>
               <Class Type = "Str"></Class>
               <CanonicalName Type = "Str"></CanonicalName>
            </Tap_0>
            <Tap_1 Type = "Branch">
               <CoreName Type = "Str">ARMCS-DP</CoreName>
               <FamilyName Type = "Str">CoreSight</FamilyName>
               <TemplateVersion Type = "Str">1:0:0</TemplateVersion>
               <DllVersion Type = "Str">rvi.dynamic.core</DllVersion>
               <Description Type = "Str">ARMCS-DP</Description>
               <DeviceID Type = "Str"></DeviceID>
               <Manufacturer Type = "Str"></Manufacturer>
            </Tap_1>
            <Tap_2 Type = "Branch">
               <CoreName Type = "Str">Cortex-M4</CoreName>
               <FamilyName Type = "Str">Cortex</FamilyName>
               <Description Type = "Str">Cortex-M4</Description>
            </Tap_2>
            <Tap_3 Type = "Branch">
            </Tap_3>
            <Tap_4 Type = "Branch">
            </Tap_4>
            <Tap_5 Type = "Branch">
            </Tap_5>
            <Tap_6 Type = "Branch">
               <CoreName Type = "Str">Cortex-A15</CoreName>
               <Description Type = "Str">Cortex-A15</Description>
            </Tap_6>
            <Tap_7 Type = "Branch">
               <CoreName Type = "Str">CSPMU</CoreName>
               <Description Type = "Str">CSPMU</Description>
            </Tap_7>
            <Tap_8 Type = "Branch">
            </Tap_8>
            <Tap_9 Type = "Branch">
            </Tap_9>
            <Tap_10 Type = "Branch">
               <CoreName Type = "Str">CSCTI</CoreName>
               <Description Type = "Str">CSCTI</Description>
            </Tap_10>
            <Tap_11 Type = "Branch">
            </Tap_11>
            <Tap_12 Type = "Branch">
               <CoreName Type = "Str">CSPTM</CoreName>
               <Description Type = "Str">CSPTM</Description>
            </Tap_12>
            <Tap_13 Type = "Branch">
            </Tap_13>
            <Tap_14 Type = "Branch">
               <CoreName Type = "Str">CSTFunnel</CoreName>
               <Description Type = "Str">CSTFunnel</Description>
            </Tap_14>
            <Tap_15 Type = "Branch">
               <CoreName Type = "Str">CSSTM</CoreName>
               <Description Type = "Str">CSSTM</Description>
            </Tap_15>
            <Tap_16 Type = "Branch">
            </Tap_16>
            <Tap_17 Type = "Branch">
               <CoreName Type = "Str">CSTPIU</CoreName>
               <Description Type = "Str">CSTPIU</Description>
            </Tap_17>
            <Tap_18 Type = "Branch">
            </Tap_18>
            <Tap_19 Type = "Branch">
               <CoreName Type = "Str">CSTMC</CoreName>
               <Description Type = "Str">CSTMC</Description>
            </Tap_19>
            <Tap_20 Type = "Branch">
               <CoreName Type = "Str">CSMEMAP</CoreName>
               <Description Type = "Str">CSMEMAP</Description>
            </Tap_20>
            <Tap_21 Type = "Branch">
            </Tap_21>
         </DataList>
      </RVConfigModule>
      <RVConfigModule>
         <?RVConfig DLL_NAME = "advanced" Expanded = "true" Active = "false" Enabled = "true" UserLabel = "" MajorVersion = "1" MinorVersion = "0" PatchVersion = "0"?>
         <ModuleName Type = "Str">Advanced</ModuleName>
         <ScanChain0BitPattern Type = "Int32">0</ScanChain0BitPattern>
            <ResetOperation Type = "UInt32">2</ResetOperation>
            <TResetOnInitConnect Type = "UInt32">0</TResetOnInitConnect>
            <SResetOnInitConnect Type = "UInt32">0</SResetOnInitConnect>
            <ResetHoldTime Type = "UInt32">100</ResetHoldTime>
            <PostResetDelay Type = "UInt32">1000</PostResetDelay>
            <nTRSTHoldTime Type = "UInt32">10</nTRSTHoldTime>
            <nTRSTPostResetTime Type = "UInt32">10</nTRSTPostResetTime>
            <DoSoftTAPReset Type = "UInt32">0</DoSoftTAPReset>
            <Linked_SRST_TRST Type = "UInt32">1</Linked_SRST_TRST>
            <AllowICETAPReset Type = "UInt32">0</AllowICETAPReset>
            <AllowICELatchSysRst Type = "UInt32">0</AllowICELatchSysRst>
            <nTRSTHighMode Type = "UInt32">0</nTRSTHighMode>
            <nTRSTLowMode Type = "UInt32">0</nTRSTLowMode>
            <nSRSTHighMode Type = "UInt32">1</nSRSTHighMode>
            <nSRSTLowMode Type = "UInt32">0</nSRSTLowMode>
            <LVDSProbeMode Type = "UInt32">1</LVDSProbeMode>
            <SWJEnable Type = "UInt32">0</SWJEnable>
            <UseDeprecatedSWJ Type = "UInt32">0</UseDeprecatedSWJ>
            <UserOut_P1 Type = "UInt32">0</UserOut_P1>
            <UserOut_P2 Type = "UInt32">0</UserOut_P2>
            <UserOut_P3 Type = "UInt32">0</UserOut_P3>
            <UserOut_P4 Type = "UInt32">0</UserOut_P4>
            <UserOut_P5 Type = "UInt32">0</UserOut_P5>
            <UserOut_P6_COAX Type = "UInt32">0</UserOut_P6_COAX>
            <SWOMode Type = "UInt32">0</SWOMode>
            <SWOBaudRate Type = "UInt32">0</SWOBaudRate>
            <PythonScript Type = "Str">from LDDI import *&#x0A;from icepick import *&#x0A;import rvi&#x0A;&#x0A;icePickConfigured = False&#x0A;def enable_ICEPICK_D(port):&#x0A;    global icePickConfigured&#x0A;    if icePickConfigured:&#x0A;        return True&#x0A;    success = reenable_ICEPICK_D(port)&#x0A;    if success:&#x0A;        icePickConfigured = True&#x0A;    return success&#x0A;&#x0A;&#x0A;def readID():&#x0A;    err = JTAG_ConfigScanChain(0, 0, 0, 0)&#x0A;    icepick.doScanIR(18, [0x03FFFF], RDDI_JTAGS_RTI, 1)&#x0A;    JTAG_ConfigScanChain(4, 0, 1, 0)&#x0A;    icepick.doScanIR(6, [0x3F], RDDI_JTAGS_RTI, 1)&#x0A;    JTAG_TMS(10, [0, 0])&#x0A;    idCode = readIDCODE([0x04],  6, 32)&#x0A;    print &quot;ICEPick IDCODE is %02x%02x%02x%02x&quot; % (idCode[3], idCode[2],idCode[1], idCode[0])&#x0A;    if err == 0:&#x0A;        JTAG_ConfigScanChain(8, 6, 2, 1)&#x0A;        idCode = readIDCODE([0x0E],  4, 32)&#x0A;        print &quot;DAP #0 IDCODE is %02x%02x%02x%02x&quot; % (idCode[3], idCode[2],idCode[1], idCode[0])&#x0A;    return 0&#x0A;&#x0A;def reenable_ICEPICK_D(port):&#x0A;    if not openJTAG():&#x0A;        return False&#x0A;    err = doTAPReset()&#x0A;    if err == 0:&#x0A;        err = JTAG_StateJump(RDDI_JTAGS_TLR)&#x0A;    icepick.wakeUpDebugLogic()&#x0A;    JTAG_ConfigScanChain(0, 0, 0, 0)&#x0A;    idCode = readIDCODE([0x04],  6, 32)&#x0A;    print &quot;ICEPick IDCODE is %02x%02x%02x%02x&quot; % (idCode[3], idCode[2],idCode[1], idCode[0])&#x0A;    icepick.connectIcepick(True)&#x0A;    icepick.writeIcepickRegister(IcepickDControl.Block,IcepickDControl.Reg.Control,IcepickDControl.Bit.D2D_POWEROVERRIDE | IcepickDControl.Bit.KEEPPOWEREDINTLR | IcepickDControl.Bit.BLOCKSYSRESET)&#x0A;    icepick.checkIcepickRegisterWriteResult()&#x0A;    flags = DebugTapLinking.Bit.FORCEACTIVE | DebugTapLinking.Bit.SELECTTAP | DebugTapLinking.Bit.DEBUGENABLE | DebugTapLinking.Bit.INHIBITSLEEP&#x0A;    icepick.writeIcepickRegister(DebugTapLinking.Block,4, flags | 0x00820000)&#x0A;    icepick.writeIcepickRegister(DebugTapLinking.Block,5, flags)&#x0A;    icepick.writeIcepickRegister(DebugTapLinking.Block,15,flags | 0x00820000)&#x0A;&#x0A;    err = readID()&#x0A;    JTAG_Disconnect()&#x0A;    return err == 0&#x0A;&#x0A;def HandleOpenConn(dev, type, state):&#x0A;    if type==1:&#x0A;        if not enable_ICEPICK_D(15):&#x0A;            return False&#x0A;&#x0A;    return handleOpenConn(dev,type,state)&#x0A;&#x0A;def UnknownStateRecovery():&#x0A;    print &quot;UnknownStateRecovery()&quot;&#x0A;    reenable_ICEPICK_D(15)&#x0A;&#x0A;def doReset():&#x0A;    if not openJTAG():&#x0A;        return False&#x0A;    print &quot;doReset&quot;&#x0A;    JTAG_ConfigScanChain(4, 0, 1, 0)&#x0A;    idCode = readIDCODE([0x04],  6, 32)&#x0A;    print &quot;ICEPick IDCODE is %02x%02x%02x%02x&quot; % (idCode[3], idCode[2],idCode[1], idCode[0])&#x0A;    icepick.connectIcepick(True)&#x0A;&#x0A;    err = readID()&#x0A;    JTAG_Disconnect()&#x0A;    return err == 0&#x0A;&#x0A;def withPossibleCoreStop(dapId, deviceId, resetfunc):&#x0A;        err, apIdx, baseAddr = getCoreSightConfig(deviceId)&#x0A;        if err == 0:&#x0A;            rvi.withV7GlobalMismatchBreakpoint(dapId, apIdx, baseAddr, resetfunc)&#x0A;        resetfunc()&#x0A;&#x0A;def HandleExeReset(flags):&#x0A;    DAPDevID = 0x06&#x0A;    A15_0DevID = 0x07&#x0A;    A15_1DevID = 0x09&#x0A;    openedDAPConn = False&#x0A;    err, id, version, message = Debug_OpenConn(DAPDevID)&#x0A;    if err == 0:&#x0A;        openedDAPConn = True&#x0A;    elif err == 0x101:&#x0A;        err = 0&#x0A;    if err == 0:&#x0A;        withPossibleCoreStop(DAPDevID, A15_0DevID,&#x0A;                         lambda: withPossibleCoreStop(DAPDevID, A15_1DevID,&#x0A;                                                      doReset))&#x0A;&#x0A;    err2 = 0&#x0A;    if openedDAPConn:&#x0A;        err2 = Debug_CloseConn(DAPDevID)&#x0A;    if err == 0:&#x0A;        err = err2&#x0A;&#x0A;    return err&#x0A;</PythonScript>
            <PowerFilterTime Type = "UInt32">100</PowerFilterTime>
         </DataList>
      </RVConfigModule>
      <JtagClockFreq Type = "UInt32" Inherited = "true">10000000</JtagClockFreq>
      <JtagClockType Type = "UInt32" Inherited = "true">0</JtagClockType>
      <RVConfigModule>
         <?RVConfig DLL_NAME = "trace" Expanded = "true" Active = "false" Enabled = "true" UserLabel = "" MajorVersion = "1" MinorVersion = "0" PatchVersion = "0"?>
            <CLOCK_EDGE Type = "Int32">0</CLOCK_EDGE>
            <DELAY_TRACE_CLOCK Type = "Int32">0</DELAY_TRACE_CLOCK>
            <DELAY_TRACE_SIGNAL_1 Type = "Int32">0</DELAY_TRACE_SIGNAL_1>
            <DELAY_TRACE_SIGNAL_2 Type = "Int32">0</DELAY_TRACE_SIGNAL_2>
            <DELAY_TRACE_SIGNAL_3 Type = "Int32">0</DELAY_TRACE_SIGNAL_3>
            <DELAY_TRACE_SIGNAL_4 Type = "Int32">0</DELAY_TRACE_SIGNAL_4>
            <DELAY_TRACE_SIGNAL_5 Type = "Int32">0</DELAY_TRACE_SIGNAL_5>
            <DELAY_TRACE_SIGNAL_6 Type = "Int32">0</DELAY_TRACE_SIGNAL_6>
            <DELAY_TRACE_SIGNAL_7 Type = "Int32">0</DELAY_TRACE_SIGNAL_7>
            <DELAY_TRACE_SIGNAL_8 Type = "Int32">0</DELAY_TRACE_SIGNAL_8>
            <DELAY_TRACE_SIGNAL_9 Type = "Int32">0</DELAY_TRACE_SIGNAL_9>
            <DELAY_TRACE_SIGNAL_10 Type = "Int32">0</DELAY_TRACE_SIGNAL_10>
            <DELAY_TRACE_SIGNAL_11 Type = "Int32">0</DELAY_TRACE_SIGNAL_11>
            <DELAY_TRACE_SIGNAL_12 Type = "Int32">0</DELAY_TRACE_SIGNAL_12>
            <DELAY_TRACE_SIGNAL_13 Type = "Int32">0</DELAY_TRACE_SIGNAL_13>
            <DELAY_TRACE_SIGNAL_14 Type = "Int32">0</DELAY_TRACE_SIGNAL_14>
            <DELAY_TRACE_SIGNAL_15 Type = "Int32">0</DELAY_TRACE_SIGNAL_15>
            <DELAY_TRACE_SIGNAL_16 Type = "Int32">0</DELAY_TRACE_SIGNAL_16>
            <DELAY_TRACE_SIGNAL_17 Type = "Int32">0</DELAY_TRACE_SIGNAL_17>
            <DELAY_TRACE_SIGNAL_18 Type = "Int32">0</DELAY_TRACE_SIGNAL_18>
            <DELAY_TRACE_SIGNAL_19 Type = "Int32">0</DELAY_TRACE_SIGNAL_19>
            <DELAY_TRACE_SIGNAL_20 Type = "Int32">0</DELAY_TRACE_SIGNAL_20>
            <DELAY_TRACE_SIGNAL_21 Type = "Int32">0</DELAY_TRACE_SIGNAL_21>
            <DELAY_TRACE_SIGNAL_22 Type = "Int32">0</DELAY_TRACE_SIGNAL_22>
            <DELAY_TRACE_SIGNAL_23 Type = "Int32">0</DELAY_TRACE_SIGNAL_23>
            <DELAY_TRACE_SIGNAL_24 Type = "Int32">0</DELAY_TRACE_SIGNAL_24>
            <DELAY_TRACE_SIGNAL_25 Type = "Int32">0</DELAY_TRACE_SIGNAL_25>
            <DELAY_TRACE_SIGNAL_26 Type = "Int32">0</DELAY_TRACE_SIGNAL_26>
            <DELAY_TRACE_SIGNAL_27 Type = "Int32">0</DELAY_TRACE_SIGNAL_27>
            <DELAY_TRACE_SIGNAL_28 Type = "Int32">0</DELAY_TRACE_SIGNAL_28>
            <DELAY_TRACE_SIGNAL_29 Type = "Int32">0</DELAY_TRACE_SIGNAL_29>
            <DELAY_TRACE_SIGNAL_30 Type = "Int32">0</DELAY_TRACE_SIGNAL_30>
            <DELAY_TRACE_SIGNAL_31 Type = "Int32">0</DELAY_TRACE_SIGNAL_31>
            <DELAY_TRACE_SIGNAL_32 Type = "Int32">0</DELAY_TRACE_SIGNAL_32>
            <DELAY_TRACE_SIGNAL_33 Type = "Int32">0</DELAY_TRACE_SIGNAL_33>
            <DELAY_TRACE_SIGNAL_34 Type = "Int32">0</DELAY_TRACE_SIGNAL_34>
            <DELAY_TRACE_SIGNAL_35 Type = "Int32">0</DELAY_TRACE_SIGNAL_35>
            <DELAY_TRACE_SIGNAL_36 Type = "Int32">0</DELAY_TRACE_SIGNAL_36>
         </DataList>
      </RVConfigModule>
      <ConnectionType Type = "Str">TCP/IP</ConnectionType>
      <VehicleType Type = "Str">DSTREAM</VehicleType>
      <LVDSProbeMode Type = "UInt32" Inherited = "true">1</LVDSProbeMode>
      <SWJEnable Type = "Int32" Inherited = "true">0</SWJEnable>
      <UseDeprecatedSWJ Type = "Int32" Inherited = "true">0</UseDeprecatedSWJ>
      <CoresightAssociations Type = "Branch">
         <Device Type = "EnumStr">Name=UNKNOWN_0;Type=</Device>
         <Device Type = "EnumStr">Name=ARMCS-DP_1;Type=ARMCS-DP</Device>
         <Device Type = "EnumStr">Name=Cortex-M4_0;Type=Cortex-M4</Device>
         <Device Type = "EnumStr">Name=ARMCS-DP_2;Type=ARMCS-DP</Device>
         <Device Type = "EnumStr">Name=Cortex-M4_1;Type=Cortex-M4</Device>
         <Device Type = "EnumStr">Name=ARMCS-DP_0;Type=ARMCS-DP</Device>
         <Device Type = "EnumStr">Name=Cortex-A15_0;Type=Cortex-A15</Device>
         <Device Type = "EnumStr">Name=CSPMU_0;Type=CSPMU</Device>
         <Device Type = "EnumStr">Name=Cortex-A15_1;Type=Cortex-A15</Device>
         <Device Type = "EnumStr">Name=CSPMU_1;Type=CSPMU</Device>
         <Device Type = "EnumStr">Name=CSCTI_0;Type=CSCTI</Device>
         <Device Type = "EnumStr">Name=CSCTI_1;Type=CSCTI</Device>
         <Device Type = "EnumStr">Name=CSPTM_0;Type=CSPTM</Device>
         <Device Type = "EnumStr">Name=CSPTM_1;Type=CSPTM</Device>
         <Device Type = "EnumStr">Name=CSTFunnel_0;Type=CSTFunnel</Device>
         <Device Type = "EnumStr">Name=CSSTM_0;Type=CSSTM</Device>
         <Device Type = "EnumStr">Name=CSCTI_2;Type=CSCTI</Device>
         <Device Type = "EnumStr">Name=CSTPIU_0;Type=CSTPIU</Device>
         <Device Type = "EnumStr">Name=CSTFunnel_1;Type=CSTFunnel</Device>
         <Device Type = "EnumStr">Name=CSTMC_0;Type=CSTMC</Device>
         <Device Type = "EnumStr">Name=CSMEMAP_0;Type=CSMEMAP</Device>
         <Device Type = "EnumStr">Name=CSMEMAP_1;Type=CSMEMAP</Device>
      </CoresightAssociations>
   </RVConfigModule>
</RVConfigUtility>
However, we are successfully able to connect and run Hello Demo on same custom board using TI Code Composer Studio with XDS200 USB Probe. Initially, we were also not able to connect with this board due to FPGA. Then we updated the .ccxml file and bypass the core. Both versions of files are attached. We need to add the difference between custom_1.ccxml and custom_2.ccxml into RVC file (tmdsevm572x_a15) attached above.
Any help would be appreciated
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<configurations XML_version="1.2" id="configurations_0">
    <configuration XML_version="1.2" id="Texas Instruments XDS2xx USB Debug Probe_0">
        <instance XML_version="1.2" desc="Texas Instruments XDS2xx USB Debug Probe_0" href="connections/TIXDS2XXUSB_Connection.xml" id="Texas Instruments XDS2xx USB Debug Probe_0" xml="TIXDS2XXUSB_Connection.xml" xmlpath="connections"/>
        <connection XML_version="1.2" id="Texas Instruments XDS2xx USB Debug Probe_0">
            <instance XML_version="1.2" href="drivers/tixds560icepick_d.xml" id="drivers" xml="tixds560icepick_d.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560arm9.xml" id="drivers" xml="tixds560arm9.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560cs_dap.xml" id="drivers" xml="tixds560cs_dap.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560cortexM.xml" id="drivers" xml="tixds560cortexM.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560cs_child.xml" id="drivers" xml="tixds560cs_child.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560c66xx.xml" id="drivers" xml="tixds560c66xx.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560dap_pc.xml" id="drivers" xml="tixds560dap_pc.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560cortexA15.xml" id="drivers" xml="tixds560cortexA15.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560csstm.xml" id="drivers" xml="tixds560csstm.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560etbcs.xml" id="drivers" xml="tixds560etbcs.xml" xmlpath="drivers"/>
            <instance XML_version="1.2" href="drivers/tixds560pru.xml" id="drivers" xml="tixds560pru.xml" xmlpath="drivers"/>
            <property Type="choicelist" Value="0" id="The JTAG TCLK Frequency (MHz)">
                <choice Name="Fixed with user specified faster value" value="SPECIFIC">
                    <property Type="stringfield" Value="10.368MHz" id="-- Enter a value from 0.5MHz to 20.0MHz"/>
                </choice>
            </property>
            <platform XML_version="1.2" id="platform_0">
                <instance XML_version="1.2" desc="AM5728_0" href="devices/AM5728.xml" id="AM5728_0" xml="AM5728.xml" xmlpath="devices"/>
                <device HW_revision="2.0" XML_version="1.2" description="AM5728 - Cortex A15 Embedded Processor&#10;Silicon Revision 2.x" id="AM5728_0" partnum="AM5728">
                    <router HW_revision="1.0" XML_version="1.2" description="ICEPick_D Router" id="IcePick_D_0" isa="ICEPICK_D">
                        <subpath id="IPU_2_C0">
                            <router HW_revision="1.0" XML_version="1.2" description="CS_DAP Router" id="CS_DAP_3" isa="CS_DAP">
                                <subpath id="CortexM4_IPU_2_C0">
                                    <cpu HW_revision="1.0" XML_version="1.2" desc="ICECrusherCS_2" description="Cross Triggering" id="ICECrusherCS_0" isa="cs_child"/>
                                </subpath>
                            </router>
                        </subpath>
                        <subpath id="IPU_2_C1">
                            <router HW_revision="1.0" XML_version="1.2" description="CS_DAP Router" id="CS_DAP_4" isa="CS_DAP">
                                <subpath id="CortexM4_IPU_2_C1">
                                    <cpu HW_revision="1.0" XML_version="1.2" desc="ICECrusherCS_3" description="Cross Triggering" id="ICECrusherCS_0" isa="cs_child"/>
                                </subpath>
                            </router>
                        </subpath>
                    </router>
                </device>
            </platform>
        </connection>
    </configuration>
</configurations>
                </choice>
            </property>
                <device HW_revision="2.0" XML_version="1.2" description="AM5728 - Cortex A15 Embedded Processor&#10;Silicon Revision 2.x" id="AM5728_0" partnum="AM5728" simulation="no">
                                    <cpu HW_revision="1.0" XML_version="1.2" desc="ICECrusherCS_2" description="Cross Triggering" deviceSim="false" id="ICECrusherCS_0" isa="cs_child"/>
                                </subpath>
                            </router>
                        </subpath>
                                    <cpu HW_revision="1.0" XML_version="1.2" desc="ICECrusherCS_3" description="Cross Triggering" deviceSim="false" id="ICECrusherCS_0" isa="cs_child"/>
                                </subpath>
                            </router>
                        </subpath>
                    </router>
                </device>
            <cpu HW_revision="1.0" XML_version="1.2" description="Bypass Cpu" id="fpga" isa="BYPASS06"/>
            </platform>
        </connection>
    </configuration>
</configurations>
Note: File extensions are changed to txt for upload.
Regards
