Hello Everyone,
My IDE-Version:
µVision V5.25.1.0Copyright (C) 2018 ARM Ltd and ARM Germany GmbH. All rights reserved.
Tool Version Numbers:Toolchain: MDK-ARM Professional Version: 5.25.1.0Toolchain Path: C:\Keil_v525\ARM\ARMCLANG\BinC Compiler: ArmClang.exe V6.9Assembler: Armasm.exe V6.9Linker/Locator: ArmLink.exe V6.9Library Manager: ArmAr.exe V6.9Hex Converter: FromElf.exe V6.9CPU DLL: SARMCM3.DLL V5.25.1.0Dialog DLL: DCM.DLL V1.17.0.0Target DLL: ULPL2CM3.dll V0.4.7.0Dialog DLL: TCM.DLL V1.34.0.0
The debugger is an arm ULINK plus.
The event recorder is enabled for 'EventRecordAll', the Event Recorder window only shows single 'Init Event' events.The RTX RTOS window shows the 'E306' line.The Command Window repeats the 'E306' line roughly once per second.The source code editor windows takes around one second to move the line highlight to a different line when clicking with the mouse.
All of this combined makes the Event Recorder unusable.
Has anyone experienced this?
Does anyone know of a workaround?
I tried to log a support case but for the last two days I just get (with a promise to resolve the issue):
'We're sorry, but something went wrong. Error ID # [c6ddd09a-144c-4375-9f19-8c8112c621f2]'.
A resolution for this issue is scheduled for the next release of MDK which should arrive in this quarter.
Please name the release you are talking about. Is it 5.26.x.y?
Is 'this quarter' Q3-2018?What is the schedule for release?
