Configuring Keil and Startup files problem
Hello everyone,
I am new to ARM, and I would like to set it up for programming in Assembly language. I am using Keil 5 and I am using LPC1768. I made a new project and built simple assembly program, but no .hex file was generated. Then I found out that I need to set up start up files in order to generate .hex file.
So under Manage Run-Time Environment -> Device-> Startup, I checked "Startup - 1.0.0 System Startup for NXP LPC1700 Series".
After project creation. Under Device folder, I got startup_LPC17xx.s (Startup) & I got system_LPC17xx.c (Startup) and I am getting error from I got system_LPC17xx.c (Startup) that there is no "core_cm3.h" file (that is beining included in system_LPC17xx.c, I tried to delete .c file but I cannot), so what should I check from Manage Run-Time Environment in order to import core_cm3.h file?
Thank you in advance
