Hi, I am trying to learn programming on an arm micro processor. I have the evaluation boar STM32F303VCT but i am running into one major problem which is the tool chain.
1. Keil gives me an error if a start a new project and i cant even find m device in files\device database.
2. I tried the same thing by creating a new project in IAR Embedded Workbench but invain. It gives me an error that ST Link could not locat mcu.
If i generate the source code from STMCUBEMX and load it into IAR Workbench everything seems to connect. Is there a better IDE for developing firmware for ARM MCU's offering intellisense as in Atmel Studio?
Best Regards
Hi Ismail, I can see the STM32F303VC device (http://www.st.com/en/microcontrollers/stm32f303vc.html) is supported in Keil MDK (http://www.keil.com/dd2/stmicroelectronics/stm32f303vc/). I guess the T at the end of the part number refers to the packaging but the device should be exactly the same. MDK (uVision editor) supports autocomplete (the generic term for intellisense): http://www.keil.com/support/man/docs/uv4/uv4_ui_codecomp.htm . MDK 5.24 improved this even further by using the same engine used by ARM Compiler 6: http://www2.keil.com/mdk5/524/
What kind of issue do you see when starting a new project? Could you please post a screenshot?
Thanks!
Stefano
