I use CMSIS/DSP library in an audio application. I have issues with the conversions 16 bits PCM (=>) Q15 => float => Q15 (=>) 16 bits PCM (in fact noreal conversion between 16 bits PCM and Q15, as I understand that it is the same thing)
I use:
arm_q15_to_float(buffer_input, inputf32, size);
arm_float_to_q15(inputf32, buffer_outputA, size);
Going through this chain, without any other DSP function provides the music restitution but adds artifacts in the sound. Some not regular tac - tac - tac possible to hear.
The input signal is a 0dB sweep that explores audible frequencies.
Without Q15 => float => Q15 conversion: no tac tac
With Q15 => float => Q15 conversion: several tac tac over few seconds
Seems frequency dependant: if I send a 440Hz sine: no tac tac
If I lower the input volume: I still have tac tac : looks not like overflows.
Are there some precautions to implement this Q15 => float => Q15 conversion process and get rid of those audio artifacts?
I implement on a nucleo stm32F7 board (Cortex M7) an audio application that is intended to get a USB music stream, apply DSP functions to perform crossover and equalization using biquads, and output the results to several digital outputs (SPDIF in my case).
I'm an hobbyist and may lack knowledge on some element that would be obvious to moreknowledgeable persons. Help would be much appreciated.
The code of the application is here https://github.com/jmf13/F7USBAudio/blob/master/Src/DSP.c.I performed my debug tests by commenting all transformations on the signal except the Q15 => float => Q15.
Best regards,
JM
After additional tests, it seems that it doesn't come from the q15/float conversion. It may be something more tricky about my SPDIF_TX management on the Stm32.
Sorry for the inconvenience.
