Hello Everyone,
Do anyone have used CMSIS USB driver to configure the controller or board as host.
I'm using LPC1837 Controller which is ARM cortex M3, this controller has has two USB port.
i'm using USB port 0, i have configure this USB 0 has host. The configure setting are made to act the Controller has USB host with CDC Class to work as Ethernet over USB. i'm facing some problem. its is giving the error message as undefined symbol Driver_USBH0 in USB_configure_0.O
i'm thinking there might me some debug, when we use the CMSIS USB driver configured as the USB host in CDC mode.
DO anyone has have come across same problems? and anyone knows how to solve this problem.
Regrads
Nagendra Murthy
Intellipredikt Technologies.
Hello Nagendra,
have you enabled and configured the USB0 in RTE_Device.h? If you are using the MDK Middleware, check out http://www.keil.com/pack/doc/mw/USB/html/_u_s_b__host.html#Create_a_USB_Host_Application that exaplains the required steps to create a USB Host application.
Kind regards,
Christopher
