fopen write error sdmmc
I am driving a 32 GB SD card with Keil MDK5 Flash File System v6.14.1 with core LFN debug mode.
Init, Mounting, and also read operations from SD card works properly. But creating or deleting a file and then open it in write mode doesn't work at all.
device: stm32H750vbt6 with ARM CORTEX-M7
core clock (frequency): 480e6
SDMMC1 configured clock (frequency): 100e6
RTOS type is  CMSIS-RTOS2 Keil RTX version 5 (RTX5)
Number of open files that configured in FS_Config.c file: 5
Heap Size = 0x2000 > 5 * (608)
Stack Size: 0x400
Card Detect Input pin and Write Protect Input pin: not available
initialization code:
//file fsys_init.c
#include "fsys_init.h"
SD_HandleTypeDef hsd1;
//fsys_init called in app_main thraed
void fsys_init(void){
	static volatile fsStatus  error_tp;
	error_tp = finit ("M:");
	if (error_tp != fsOK)
    fsys_error_handler(fsys_finit_error, error_tp);
  osDelay(10);
  // Mount the M: drive.
	error_tp = fsOK + 1;
	while(error_tp != fsOK ){
		error_tp = fmount ("M:");
	//HAL_SD_MspInit(&hsd1);
* @brief SD MSP Initialization
* This function configures the hardware resources used in this example
* @param hsd: SD handle pointer
* @retval None
void HAL_SD_MspInit(SD_HandleTypeDef* hsd)
  GPIO_InitTypeDef GPIO_InitStruct = {0};
  RCC_PeriphCLKInitTypeDef PeriphClkInitStruct = {0};
  if(hsd->Instance==SDMMC1)
  /* USER CODE BEGIN SDMMC1_MspInit 0 */
  /* USER CODE END SDMMC1_MspInit 0 */
  /** Initializes the peripherals clock
    PeriphClkInitStruct.PeriphClockSelection = RCC_PERIPHCLK_SDMMC;
    PeriphClkInitStruct.PLL2.PLL2M = 1;
    PeriphClkInitStruct.PLL2.PLL2N = 25;
    PeriphClkInitStruct.PLL2.PLL2P = 2;
    PeriphClkInitStruct.PLL2.PLL2Q = 2;
    PeriphClkInitStruct.PLL2.PLL2R = 2;
    PeriphClkInitStruct.PLL2.PLL2RGE = RCC_PLL2VCIRANGE_3;
    PeriphClkInitStruct.PLL2.PLL2VCOSEL = RCC_PLL2VCOWIDE;
    PeriphClkInitStruct.PLL2.PLL2FRACN = 0.0;
    PeriphClkInitStruct.SdmmcClockSelection = RCC_SDMMCCLKSOURCE_PLL2;
    if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct) != HAL_OK)
      fsys_error_handler(0, 0);
    /* Peripheral clock enable */
    __HAL_RCC_SDMMC1_CLK_ENABLE();
    __HAL_RCC_GPIOC_CLK_ENABLE();
    __HAL_RCC_GPIOD_CLK_ENABLE();
    /**SDMMC1 GPIO Configuration
    PC8     ------> SDMMC1_D0
    PC9     ------> SDMMC1_D1
    PC10     ------> SDMMC1_D2
    PC11     ------> SDMMC1_D3
    PC12     ------> SDMMC1_CK
    PD2     ------> SDMMC1_CMD
    GPIO_InitStruct.Pin = GPIO_PIN_8|GPIO_PIN_9|GPIO_PIN_10|GPIO_PIN_11
                          |GPIO_PIN_12;
    GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Pull = GPIO_NOPULL;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
    GPIO_InitStruct.Alternate = GPIO_AF12_SDIO1;
    HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
    GPIO_InitStruct.Pin = GPIO_PIN_2;
    HAL_GPIO_Init(GPIOD, &GPIO_InitStruct);
    /* SDMMC1 interrupt Init */
    HAL_NVIC_SetPriority(SDMMC1_IRQn, 0, 0);
    HAL_NVIC_EnableIRQ(SDMMC1_IRQn);
  /* USER CODE BEGIN SDMMC1_MspInit 1 */
  /* USER CODE END SDMMC1_MspInit 1 */
void fsys_error_handler(fsys_error id, fsStatus  error_tp){
	__asm("BKPT #0");
After debugging the following events occurred when I tried to open and create "M:\filesys\Dump_file.logo" in write mode:
Event, Time (sec), Component, Event Property, Value
0, 0.00039830, EvCtrl, EventRecorderInitialize, Restart Count = 1
1, 0.00040655, EvCtrl, EventRecorderStart,
2, 0.00236864, EvCtrl, EventRecorderInitialize, Restart Count = 2
3, 0.00237939, EvCtrl, EventRecorderStart,
4, 0.00262214, FsCore, finit, drive=0x0800AFBC
5, 0.23689052, FsCore, fmount, drive=0x0800AFBC
6, 6.21071641, FsCore, sys_open, name=0x080048C8  openmode=0x00000004
7, 6.34828006, FsFAT, FileIsNonExistent, drive=M0
8, 6.47961456, FsMcMCI, TransferError, instance=0  events=0x00000084
9, 6.52405997, FsMcMCI, TransferError, instance=0  events=0x00000084
10, 6.56378528, FsMcMCI, TransferError, instance=0  events=0x00000084
11, 6.60354884, FsMcMCI, TransferError, instance=0  events=0x00000084
12, 6.64327516, FsMcMCI, TransferError, instance=0  events=0x00000084
13, 6.68302375, FsMcMCI, TransferError, instance=0  events=0x00000084
14, 6.72276447, FsMcMCI, TransferError, instance=0  events=0x00000084
15, 6.76250128, FsMcMCI, TransferError, instance=0  events=0x00000084
16, 6.80345253, FsFAT, SectorWriteFailed, drive=M0  sector=32640  count=1
The event TransferError is generated when data transfer is active and data block CRC check fails or Memory Card Control Layer does not receive ARM_MCI_EVENT_TRANSFER_COMPLETE event from the MCI driver.
Clever engineers, please help me to solve these bad events!!
There are no posts to show. This could be because there are no posts in this forum or due to a filter.
