Greetings,
I am currently working on a project to implement the ARM RTX RTOS2 for multiple modules (such as NAND, SPI, UART, ETHERNET, etc.) on a custom board.
I have downloaded the latest template for Driver_Nand.h and Driver_Nand.c from the CMSIS5-develop repo on Github (https://github.com/ARM-software/CMSIS_5).
However, when I look through the Driver_Nand.c when I call the Initialize function with API version (0x204) I see the following:
static int32_t ARM_NAND_Initialize (ARM_NAND_SignalEvent_t cb_event) { return ARM_DRIVER_ERROR_UNSUPPORTED;}
I, therefore assume the support for NAND-flashes was removed. If that is the case, why was the support for ARM_NAND removed, and is there any replacement?
Furthermore, I have already got it to work through using it directly as GPIO pins and read/write to the assigned pins (as an alternative). I wish to use the arm_driver structure for the operation to have the same structure programmatically on the initialization, read and write operations as for the other parts (such as SPI).
Best regards,
0x80.
Support for NAND Flash was not removed. The template Drive_Nand.c that you mention is not a working driver but just a template. It is a skeleton that can be used when developing such a driver.
You can take a look at an example of a generic NAND Flash driver for devices connected directly to a memory bus:
github.com/.../NAND_MemBus.c
Ah, I thought it was "a bit strange" that the whole support for it was removed and no mention it at all.
Thank you for pointing me in the right direction.
