UVision5 - object file xxx renamed to yyy bug
I have been working for some time on a project in uVision5. It's been fine until now. Today I added some new targets to differentiate builds for different products, and suddenly I am getting a lot of messages like this, and the project does not build.
*** Using Compiler 'V5.06 update 7 (build 960)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Rebuild target 'BROADCAST'
Note: source file 'C:\Projects\Rubidium\DialogSDK\6.0.14.1114\sdk\platform\arch\boot\system_DA14531.c' - object file renamed from '.\out_BROADCAST\Objects\system_DA14531.o' to '.\out_BROADCAST\Objects\system_d'.
error - cannot create command input file '.\out_broadcast\objects\objects\.__i'
Target not created.
Build Time Elapsed:  00:00:00
I can clear the fault by closing uVision, deleting the build folders for the targets and then trying to build. This is making the IDE virtually unusable.
What is causing this?
There are no posts to show. This could be because there are no posts in this forum or due to a filter.
