Where is main.c file located in Keil uVision 5?
I've done several projects using Keil uVision 5, and I noticed in the project folders there is no main.c file. The only reference to main is in the Objects folder where I can see the main.o, main.d and main.crf. If I open the project file XYZ.uvprojx as an example, the project opens up and I can see the main file. Is there a way I can make the main.c file visible or is it already located somewhere?
