ARM assembly - Fibonacci Implementation: PUSH and POP not working as expected
 have written this ARM assembly code. It is supposed to put the Fibonacci sequence numbers in R4 register. I'm trying to implement this C code in assembly:
int fibbonacci(int n)
       if(n == 0)
           return 0;
       else if(n == 1)
          return 1;
       else
          return (fibbonacci(n-1) + fibbonacci(n-2));
This is the assembly code I have written:
                   AREA |.text|, CODE, READONLY
                  EXPORT Fib
Fib
;R0(n) - store the first n numbers in the Fibonacci sequence
;R1    - address of the first element in the array to store the Fibonacci sequence
MOV      R4, #0
    MOV      R5, #0
    MOV      R6, #1
FiboR
    CMP      R0, #1
    PUSHEQ   {R5, R6, LR}
    BEQ      Return
    SUBS     R0, R0, #1
    BL       FiboR
    ADD      R4, R2, R3
    PUSH     {R4, R2, LR}
Return
    POP      {R2, R3, PC}
    ALIGN             END
It is not behaving exactly like that posted C code so far because I need to keep working on it and make it return to main after it prints the first 5 numbers. However for now I need to fix something.
When my code reaches this line:
PUSH     {R4, R2, LR}
It's supposed to push values R4, R2 and LR on the stack which at that moment are: 1, 0, LR. Then the code goes down into the 'Return' subroutine in which I'm doing this:
POP      {R2, R3, PC}
So at this moment R2 should be loaded with value 1, R3 with value 0 and PC with value of LR so I return to this line:
ADD      R4, R2, R3
The code does return to the ADD line however the value of R2 is not loaded with the value 1 as I expected it to. My code stays here in an infinite loop and I keep pushing {1, 0, LR} on the stack but when I try to pop these values into R2, R3 and PC apparently they are not getting popped as I would expect them to at least value 1 does not go into R2 and R2 keeps it's value of 0 forever.
Can you please help me what am I missing here? Thank you for reading!
  • Multi-register PUSHES are always done in ascending register order, so what may LOOK like
    PUSH {R4,R2,LR}
    is actually
    PUSH {R2, R4, R14}
    so R2 is pushed first, to the highest stack address, and R14 (LR) is pushed last, to the lowest stack address.
    Apply the reverse logic for POPs.
    I imagine that is playing havoc with your logic ;)
    PUSH {R4,R2,LR}
    is actually
    PUSH {R2, R4, R14}
