I am using teensy 3.2 to program its K20 series microcontroller Mk20DX256 I have written a simple UART code to transmit a character 'U' from teensy to PC and see it on Docklight.I have disabled interrupt and DMA
I have searched through web and found out that Teensy acts as Serial port only when Serial type code is running Otherwise it acts as USB Port
Can anyone please tell me how to tell the KEIL IDE that you want to link in a USB stack and how you want it configured?Please guide if anything is wrong in my code
#include "MK20D7.h" void UARTPutChar(char); int main() { SIM->SCGC4=1UL<<10; //Clock Enable Uart0 SIM->SCGC5 =1UL<<12;//Enable GPIO PORT A clock UART0->C2=0X00; //Disable UART PORTD->PCR[7]= 0x00000300; //Port pin declare as UART0TX UART0->BDH=0x01; // UART0->BDL=0xD4; UART0->C1=0X00; UART0->C3=0X00; UART0->S2=0X20; UART0->S1=0X40; UART0->C2=0X08; //Enable UART0 while(1) { UARTPutChar('U'); } } void UARTPutChar(char ch) { if(UART0->S1 == 0X40) { UART0->D=ch; } }
