Errors L6366E & L62242E
I created a static library for the micro-ecc project using GNU Arm Embedded Toolchain:
arm-none-eabi-gcc -Wall -c uECC.c
and armar:
armar -rcs libuECC.a uECC.o
I added the library file to my Keil Project and I get this error:
Build started: Project: xxx
*** Using Compiler 'V5.05 update 1 (build 106)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'
Build Project 'app_main' - Target 'xxx'
linking...
.\release\xxx.axf: Error: L6366E: uECC.o attributes are not compatible with the provided cpu and fpu attributes .
Object uECC.o contains Build Attributes that are incompatible with the CPU attributes.
Tag_CPU_arch = ARM v4T (=2)
Tag_THUMB_ISA_use = Thumb instructions were permitted to be used (=1)
Tag_ARM_ISA_use = ARM instructions were permitted to be used (=1)
.\release\xxx.axf: Error: L6242E: Cannot link object uECC.o as its attributes are incompatible with the image attributes.
... wchart-16 clashes with wchart-32.
... arm-isa clashes with m-profile.
Not enough information to list image symbols.
Not enough information to list load addresses in the image map.
Finished: 8 information, 0 warning and 2 error messages.
".\release\xxx.axf" - 2 Error(s), 0 Warning(s).
Target not created.
Build Time Elapsed: 00:00:02
If I try to link just the object file on its own (not a static library), I get the same error.
I realize that I'm using an old version of the ARM compiler and upgrading might fix these issues; but I just wanted to know if there is a workaround that I could try first.
