i am having trouble with my nucleo 64 stm32f401ret and keil uvision 5.33 when i compile and build my code i get no errors or warnings using code generated by cubemx. but when i try to flash my code i keep getting the error flashing failed cortex m4 can somone help
What exactly do the build / debug windows show with respect to this failure?
Do you select an ST-LINK as a debugger in the debug pane of the options? Does it see the device?
