Hi all,
Recently I've installed properly the uvision 5, however if I go to Options-->Utilities--> settings and try to add a flash programming algorithm I cannot find stm32f4xx flash algorithm. Do you know step by step how can I add this algorithm that I need it?(I have discovery stm32f4 board and need that algorithm).
Thanks in advance
Did you use the Pack Installer and install the "stm32f4 Series" pack? If not, you need to open the pack installer and install the pack for STM32f4.
Yes ,I did, perhaps I have the issue as I'm using windows 10 othwerwise I have nu clue, I did everything step by step. I've even tried to install a previous version of stm32f4 pack but didn't work, get stuck at 84%.In uvision still the same stm32f4xx flash algorithm is not there.
