UVSOCK: Change SN in J-Link/J-Trace Adapter settings
Hello Community,
At the moment im writing a Interface to communicate with keil uvision out of a c# application by using UVSOCK.
(https://www.keil.com/appnotes/docs/apnt_198.asp)
So far all works fine, but now i have to make a few changes in the J-Link/J-Trace settings. For example Change the SN:.
(GUI way: OptionsForTarget->Debug->settings->Debug->SN:)
As far as i can see no function is provided by UVSOCK to change settings here.
But maybe someone has already come a cross a similar problem and has found a solution or i missed a function which is able to do this and u can tell me ?
Regardless if you can help me, have a nice day and good luck for your projects.
Greets Hannes
