Hi all,
I have integrated the PCLint 9 into Keil and I want to do Misra C checking for my code! But I don't know how to config the Misra C in PCLint integrated in Keil. For example, I don't want to follow Misra C 2004:
/* Rule 2.2 (req) **********************************/// <!c> Rule 2.2 (required): Source code shall only use /* ... */ style comments. //-e950 /* flag non-ANSI word or construct */ //-elib(950)// </c>
How can I disable this item?
Thanks a lot!
BR!
You can simply remove the comments by editing the file directly or use the Configuration Wizard.
The result should be the same:
-e950 -elib(950)
Please take a look at the documentation how to configure PC-Lint with uVision:
www.keil.com/.../uv4_ut_pclint_config.htm
