ULINKpro Problem with MDK 5.32
I installed the latest update MDK5.32 and was using MDK5.31 before.
I noticed that during the update process several debugger-specific files/driver were updated.
After the update UKINKpro does not detect my target LPC4367 any more and I cannot start debugging.
I noticed: when I go to the tab "Pack" , clear the "Enable" checkbox,  and go back to the Tab "Debug", the device is found again and flashing the firmware works again (but not debugging).
At the same time I do not see any problems with a different project based in an LPC56418 (flashing and debugging works without any problems)
After uninstalling V5.32 and installing V5.31 again (and confirm to update drivers for debugger) everything works again as before.
