Hello everyone again, I have a question, can you reset a microcontroller with the ULINK2? I found information on the ARM page, as I said that the reset process is done according to the manufacturer, but I am not clear if to use this Keil uVision IDE you have to specify something or as this matter so my question from the beginning.The microcontroller that I use is an arduous MKRZero is a SAMD21 of ATMEL(MICROCHIP), without more that to add that have a good day.
antouriel123 said:can you reset a microcontroller with the ULINK2?
It can drive the reset line, and it can command a reset via JTAG or SWD
The uLink Documentation is here: www2.keil.com/.../ulink2
uVision Documentation: https://www.keil.com/support/man/docs/uv4/
Specifically, the debug configuration: www.keil.com/.../uv4_dg_debug.htm
