I am trying to import .cpp file to stm32f103c8 CubeMX project. I have a CPP file I want to import to keil. How can I compile CPP and C files at the same time on Keil. Can I do that?
I want to use the HAL library also I have one cpp file. I couldn't figure out how compiler settings should be.
Thank you for your help.
winterGrey said:How can I compile CPP and C files at the same time on Keil.
exactly the same way you'd do it in any other environment.
Only last week:
community.arm.com/.../combining-c-and-c-libraries
Thank you, Andy I will try the recommendations.
