CMSIS cortex M startup file, scatter file STACK, HEAP size definitions
I'm currently using CMSIS 5.7.0 with ARM compiler 5.
I noticed that there are 2 locations where HEAP, STACK size are defined.
files are located in CMSIS 5.7.0 directory: ARM.CMSIS.5.7.0/Device/_Template_Vendor/Vendor/Device/Source/ARM
  1. scatter file : Device_ac5.sct
  2. assembly startup file: startup_Device.s
In the scatter file, it defines STACK/HEAP size and it's placement defined as ARM_LIB_HEAP and ARM_LIB_STACK.
/*--------------------- Stack / Heap Configuration ---------------------------
; <h> Stack / Heap Configuration
;   <o0> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
;   <o1> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
; </h>
#define __STACK_SIZE    0x00000200
#define __HEAP_SIZE     0x00000C00
LR_ROM __RO_BASE __RO_SIZE  {                       ; load region size_region
  ER_ROM __RO_BASE __RO_SIZE  {                     ; load address = execution address
   *.o (RESET, +First)
   *(InRoot$$Sections)
   .ANY (+RO)
   .ANY (+XO)
  RW_RAM __RW_BASE __RW_SIZE  {                     ; RW data
   .ANY (+RW +ZI)
#if __HEAP_SIZE > 0
  ARM_LIB_HEAP  __HEAP_BASE EMPTY  __HEAP_SIZE  {   ; Reserve empty region for heap
#endif
  ARM_LIB_STACK __STACK_TOP EMPTY -__STACK_SIZE {   ; Reserve empty region for stack
In the assembly startup file, it also defines STACK/HEAP size as below.
;<h> Stack Configuration
;  <o> Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
;</h>
Stack_Size      EQU      0x00000400
                AREA     STACK, NOINIT, READWRITE, ALIGN=3
__stack_limit
Stack_Mem       SPACE    Stack_Size
__initial_sp
;<h> Heap Configuration
;  <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
;</h>
Heap_Size       EQU      0x00000C00
                IF       Heap_Size != 0                      ; Heap is provided
                AREA     HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE    Heap_Size
__heap_limit
                ENDIF
                PRESERVE8
                THUMB
I find this troublesome since if I have to modify both files at the same time.
Is there a reason for this?
I have also noticed the corresponding new startup_Device.c does not redefine stack/heap size like in the assembly startup file.
Thanks ahead for the help!
  • The mentioned assembly startup is based on the older approach where startup was standalone and STACK/HEAP was configured within the startup file rather than with the linker scatter file. This is being deprecated.
    The newer “C Startup” variant includes the C startup combined with linker scatter file that configures STACK/HEAP. The new scatter file should only be used together with the C startup and is not needed when using the legacy assembly startup.
