I'm a novice with STM32 and Keil. I'd like to use a BMP280 C library and a RFM69 C++ library. I wasn't able to understand how to use both in the same project. Can someone share some advice/guidance? The C++ library uses .hpp files and they were not recognized. I was probably making a mistake. Thank you in advance for any help.
Frank
The techniques for mixing 'C' and C++ are standard - not specific to Keil - so should be covered in standard references.
one key factor is the use of
extern "C"
fjr0215 said:I'm a novice with STM32 and Keil
Are you familiar with using STM32 in any other IDE(s) ?
Are you familiar with using any other microcontroller(s) ?
Are you familiar with 'C' and/or C++ programming in general ?
For learning, start here:
http://www2.keil.com/mdk5/learn
See also: https://www.keil.com/books/
Thank you. I will take a look at those resources. No I've not used STM32 in other IDE's. I've used other microcontrollers, but at a higher level of abstraction. I am familiar with C and a have less experience with C++ .
