Hi, I'm working with LPC1768 MC & using the MDK simulator. My assembly code is involving strings. When I declare the string in data segment, it doesnt get reflected in memory window during the debug session. But if I declare the string in code segment, it gets reflected in the memory window during the debug session. Can anyone let me know, why this is happening?
Can you show an example? A picture or some code showing how you declare/define the strings that work and those that don't?
Simulating an LPC1768 in Keil MDK 5.31 seems to work just fine: strings defined as constant data, on the stack, or on the heap show up in the debugger as strings.
Thanks for replying. Here are the code examples.
For the simple code below the ascii value of the string appears in the memory window. Here the string is declared after the code.
AREA data1, DATAADD1 EQU 0x1000000
AREA prog, CODE ENTRY EXPORT __main2__main2 LDR R1, = ADD1 LDR R2, =string LDRB R3, [R2] stop B stop string DCB "abcd" END
But for the code below the ascii value does not appear in the memory window. Here the string is declared separately in data segment.
AREA data1, DATAstring DCB "abcd"
ALIGN
ADD1 EQU 0x1000000
AREA prog, CODE ENTRY EXPORT __main2__main2 LDR R1, = ADD1 LDR R2, =string LDRB R3, [R2] stop B stop END
Please let me know the reason behind this issue.
//Example of string being declared in code segment. AREA data1, DATA ADD1 EQU 0x1000000 AREA prog, CODE ENTRY EXPORT __main2 __main2 LDR R1, = ADD1 LDR R2, =string LDRB R3, [R2] stop B stop string DCB "abcd" END
//Example of code being declared in Code segment AREA data1, DATA ADD1 EQU 0x1000000 string DCB "abcd" AREA prog, CODE ENTRY EXPORT __main2 __main2 LDR R1, = ADD1 LDR R2, =string LDRB R3, [R2] stop B stop END
