Hi
I am developing a project with 7 inch touch screen display
But the key is sensing automatically without touching
Why is this issue
I am reading touch screen by directly reading through 12 bit internal ADC
please give me some suggestions
R Sridhar
What gave you the idea that this has anything to do with the compiler you're using?
SRIDHAR R said:please give me some suggestions
Carefully study all the documentation, application notes, guidance, examples, etc from the screen manufacturer/supplier
Double-check that you have completely & correctly applied all that information
If you're still having problems, contact screen manufacturer/supplier for support - it has nothing to do with Keil or ARM.
Thanks sir for you suggestions It is working fine now
May be some issues with hardware
