I'm trying to convert an existing Keil MDK ARM uvproj to the uvprojx version.
on : https://www.keil.com/support/man/docs/uv4/uv4_commandline.htm
It seems it's possible to use the command UV4 -5 myoldproject.uvproj -l log.txt
if I'm trying this , UVV4 is only opens the log.tt file without doing anything else.
I'm using Keil uVision 5.24.2
Regards,
Yann
