My ULINKPro ribbon cable connector has broken - the pin from the adaptor (HPI-0195C) connector has snapped off into the hole of the cable connector. Difficult to explain but ...
ULINKPro---------ribbon cable --------| |--adaptor--| target
It's broken at the || point.
Where can I get a replacement - I don't want to replace the ULINKPro pod itself, just the cable and adaptor.
TIA
You can contact your local distributor where you purchased your ULINKpro for such a ribbon cable:
http://www.keil.com/distis/
