Good day to you all! Now I have another problem with the DEBUG I got this error "device could not be powered" and in the Build output message it is as follows:
I use the ULINK2 debugger to program a SAMD21G18A from ATMEL, Thanks for helping me with the problem of unnamed reserve bits but now this problem came up, thanks in advance and I hope your answer soon.
See: related "Error Messages"
https://www.keil.com/support/man/docs/ulink2/ulink2_errors.asp
and check your ULINK2 with the help of this Troubleshooting Guide:
http://www.keil.com/support/man/docs/ulink2/ulink2_trblshooting.htm
Hello, Good Morning!I already checked the ULINK2/ME and it works with the steps you provided me so the fault is in the microcontroller, now my doubt is, in these cases can the microcontroller be unlocked with the same ULINK2 And if I could indicate to the Keil uvision IDE, because I was consulting precisely the manuals and they said that to make the reset operation it was according to each microcontroller, is it true? or also I found this, I don't know if this information is valid?
developer.arm.com/.../application-interrupt-and-reset-control-register
At MDK's Flash Download Option configure for 'Erase Full Chip' and retry.
It also would be worth contacting the Chip vendor themselves for details.
many I will try to contact the distributor to see if I can find an answer
You didn't give the link to your original post:
https://community.atmel.com/forum/device-could-not-be-powered-samd21
Please also update that thread with a link to this - as advised.
antouriel123 said:I got this error "device could not be powered"
You still haven't explained where, exactly, you see that message or what you're doing when it happens.
antouriel123 said:program a SAMD21G18A from ATMEL
What board is it on?
If it's your own custom board, how have you proved that the board design is correct, and the hardware good?
Before going to a custom board, have you been able to program a chip on a known-working Dev Board or similar?
I was able to solve the problem, I reloaded the bootloader of the arduino MKRZero with ATMEL ICEthey got in the company, thank you.I didn't know you were also at ATMEL COMMUNITY.A thousand apologies!
You still need to update your thread on the Atmel Community.
