Actually I read from the Mastering in the FreeRTOS documentation that,
/* If all is well then main() will never reach here as the scheduler will now be running the tasks. If main() does reach here then it is likely that there was insufficient heap memory available for the idle task to be created. Chapter 2 provides more information on heap memory management. */ for( ;; );
what if I removed for( ;; ); from the main? I mean in case if anything happens in the project and if the control goes to that infinite loop then the product will hang forever.
So my question is why we use this?? can we remove it??
missing the required endless loop I expect that your program terminates within a sys_exit() (or similar) call
Okay Thank you sir.
