While trying to code LPC2148, I'm getting this error. I'm using,
KeiluVisionv5.31
Rebuild started: Project: lkn*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'Rebuild target 'Target 1'Clean started - Project: 'lkn' deleting intermediate output files for target 'Target 1'assembling Startup.s...Startup.s: Error: A9580E: ARM7 is not available with the current toolkit and license. Check that ARM_TOOL_VARIANT is set correctly.Startup.s: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at:Startup.s: www.keil.com/.../license_management.htmStartup.s: If you need further help, provide this complete error report to your supplier or license.support@arm.com.Startup.s: - ARMLMD_LICENSE_FILE: unsetStartup.s: - LM_LICENSE_FILE: unsetStartup.s: - ARM_TOOL_VARIANT: unsetStartup.s: - ARM_PRODUCT_PATH: unsetStartup.s: - Product location: C:\Keil_v5\ARM\sw\mappingsStartup.s: - Toolchain location: C:\Keil_v5\ARM\ARMCC\BinStartup.s: - Selected tool variant: mdk_liteStartup.s: Product: MDK-ARM Lite 5.31Startup.s: Component: ARM Compiler 5.06 update 6 (build 750)Startup.s: Tool: ArmAsm [4d35ec]Startup.s: error: A3903U: Argument 'ARM7TDMI' not permitted for option 'cpu'.".\Objects\lkn.axf" - 2 Error(s), 0 Warning(s).
*** Performing Cross-Module-Optimization:*** Feedback file '.\Objects\lkn.fed' not found.Target not created.Build Time Elapsed: 00:00:01
http://www2.keil.com/mdk5/selector
ARM7TDMI is not supported in the Lite or Essential version of the license.
Even after adding legacy packages for ARM7, its not working....while with v5.29 it works fine.
The support of Arm 7/9 devices is limited to MDK Pro and MDK Plus edition of licenses in the latest versions:http://www2.keil.com/mdk5/selector
