While trying to code LPC2148, I'm getting this error. I'm using,
KeiluVisionv5.31
Rebuild started: Project: lkn*** Using Compiler 'V5.06 update 6 (build 750)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'Rebuild target 'Target 1'Clean started - Project: 'lkn' deleting intermediate output files for target 'Target 1'assembling Startup.s...Startup.s: Error: A9580E: ARM7 is not available with the current toolkit and license. Check that ARM_TOOL_VARIANT is set correctly.Startup.s: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at:Startup.s: www.keil.com/.../license_management.htmStartup.s: If you need further help, provide this complete error report to your supplier or license.support@arm.com.Startup.s: - ARMLMD_LICENSE_FILE: unsetStartup.s: - LM_LICENSE_FILE: unsetStartup.s: - ARM_TOOL_VARIANT: unsetStartup.s: - ARM_PRODUCT_PATH: unsetStartup.s: - Product location: C:\Keil_v5\ARM\sw\mappingsStartup.s: - Toolchain location: C:\Keil_v5\ARM\ARMCC\BinStartup.s: - Selected tool variant: mdk_liteStartup.s: Product: MDK-ARM Lite 5.31Startup.s: Component: ARM Compiler 5.06 update 6 (build 750)Startup.s: Tool: ArmAsm [4d35ec]Startup.s: error: A3903U: Argument 'ARM7TDMI' not permitted for option 'cpu'.".\Objects\lkn.axf" - 2 Error(s), 0 Warning(s).
*** Performing Cross-Module-Optimization:*** Feedback file '.\Objects\lkn.fed' not found.Target not created.Build Time Elapsed: 00:00:01
The support of Arm 7/9 devices is limited to MDK Pro and MDK Plus edition of licenses in the latest versions:http://www2.keil.com/mdk5/selector
Even after adding legacy packages for ARM7, its not working....while with v5.29 it works fine.
ARM7TDMI is not supported in the Lite or Essential version of the license.
