Hello everyone!
I am using Keil uVision 5.28 with Compiler V6.12.
How to declare a constant structure in flash memory so that it is not initialized by programmer / debugger and functions from scatterloader?
I'm looking at document https://static.docs.arm.com/100748/0609/compiler_user_guide_100748_0609_00_en.pdf.
There is an example on page 120 for peripheral registers, but it does not quite suit me, since there can be many such structures, and I do not want to make many files for each structure.
Now I have limited the size of the flash memory in the scatter file and refer to the structure at an absolute address.Maybe there is some other, more correct solution?
It's fine -- ZI is really a synonym for .bss. See also section B3.34 in the Arm Compiler Reference Guide v6.14.
Thanks for the answer.
My scatter file:
LR1 0x08000000 0x0007C800 { USRROM 0x08000000 0x0007C800 { *.o (RESET, +First) *(InRoot$$Sections) .ANY (+RO) .ANY (+XO) } NVRAM 0x20000000 UNINIT 0x00000008 { *.o (.bss.dfuflg) } USRRAM 0x20000008 0x0000FFF8 { .ANY (+RW +ZI) } } LR2 0x0807E800 0x00001000 { NVROM1 0x0807E800 UNINIT 0x00001000 { *.o (.bss.wtime) } } LR3 0x0807F800 0x00000800 { NVROM2 0x0807F800 UNINIT 0x00000800 { *.o (.bss.nvm) } }
In my source code:
static const u32 Var[10] __attribute__((section(".bss.nvm")));
Moreover, in the message "Program size: code = 16176 RO-data = 1732 RW-data = 16 ZI-data = 7904" I notice that my array (for example, or structure) is placed in ZI-data.Does this violate linker logic?
The linker can collect all of the structures from different files for you. As the manual says, use __attribute((section(".bss.noinit"))) to name them, and use ANY (.bss.noinit) in the scatter file to pull them into a section marked with UNINIT. ANY is more useful that using *, and avoids needing to specify the files individually.
