So I am doing a project where I need to interface an TFT LCD 240*240 ISP ST7789 with C8051f120 microcontroller using SPI interface I have written the program but I am not getting Output on LCD would appreciate if anybody will help :) here's my code do let me know if there's any problem with code. P.S I have initialized the port and mcu parameters in c8051f120.h
#include <c8051f120.h> #include <tft.h> #include <stdio.h> #include <stdlib.h> #include <intrins.h> sbit SPI_SCLK=P2^1; sbit SPI_MISO=P2^3; sbit SPI_MOSI=P2^2; void main() { SFRPAGE = SPI0_PAGE; delayms(100); ST7789V_Initial(); delayms(100); SPI0CN = 0xF8; Draw_Circle(); BACK_COLOR=WHITE; POINT_COLOR=RED; delayms(140); } void Draw_Circle(unsigned int x0,unsigned int y0,unsigned char r,unsigned int color) { int a,b; a=0;b=r; while(a<=b) { LCD_DrawPoint(x0-b,y0-a,color); //3 LCD_DrawPoint(x0+b,y0-a,color); //0 LCD_DrawPoint(x0-a,y0+b,color); //1 LCD_DrawPoint(x0-a,y0-b,color); //2 LCD_DrawPoint(x0+b,y0+a,color); //4 LCD_DrawPoint(x0+a,y0-b,color); //5 LCD_DrawPoint(x0+a,y0+b,color); //6 LCD_DrawPoint(x0-b,y0+a,color); //7 a++; if((a*a+b*b)>(r*r)) { b--; } } }
Please give your posts a more descriptive title!
What makes you think that this is anything to do with Keil?
How have you proved that your hardware is correct & working?
HasanSK said:C8051f120
This device has on-chip debug - have you used it to see what your code is actually doing?
Have you used a logic analyser and/or oscilloscope to see what's happening on the wires?
Before doing a (relatively) advanced project like this, have you successfully completed a basic one - such as blinking an LED?
www.avrfreaks.net/.../1138166
