Dear Expert:
In Keil uVision5, when I rebuild the project, it failed and the error message was like:
*** Using Compiler 'V5.06 update 4 (build 422)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'Rebuild target 'rom_patch_device'Before Build - User command #1: python ../../../scripts/map2sct.py ../../../out/obj/tps65988_AppFW.map patch_layout.sct*** Error: CreateProcess failed, Command: 'python ../../../scripts/map2sct.py ../../../out/obj/tps65988_AppFW.map patch_layout.sct'
compiling patch_header.c...compiling patch_amdi2cmux.c...compiling patch_globals.c...
(too many, omit)
compiling patch_adc.c...compiling patch_flash.c...
"..\out_device\rom_patch_device.axf" - 1 Error(s), 0 Warning(s).Target not created.Build Time Elapsed: 00:00:13
Maybe the sentences in red is the cause of the failure. Could you please tell me what does it mean and how to solve the problem?
Many thanks.
Regards,
Bing
