Where is the current documentation for creating a DLL for a debugging probe?
Application Note 173: AGDI for ARM target systems seems to have disappeared, so I presume that it has been superseded. Application Note 145 does not apply to ARM and is ancient as well as fairly difficult to get to compile on modern Visual Studio's.
Thanks.
I believe CMSIS-DAP is the modern way. Did you see this page? Source is provided within the CMSIS pack. Probably it's easier to build than the AN145 code.
CMSIS-DAP is not a solution since the abstraction is at the wrong level. CMSIS-DAP is meant for banging bits on cheap probes and is a huge bottleneck. USB doesn't help either.
In my instance, I want to talk to my debugging probe via Ethernet directly from Keil. Eventually, I want to be able to do trace over Ethernet.
This clearly is possible as the Segger stuff does this. What I need, however, is the specification.
Recommend contacting ARM technical support for that.
