Hallo everyone.uhh latley i have been have issue when i auto generate a code with cubemx it doesnt load the startp s file for the board as you can see in the text underBuild started: Project: test*** Using Compiler 'V6.14', folder: 'C:\Keil_v5\ARM\ARMCLANG\Bin'Build target 'Target 1'ArmClang: error: no such file or directory: 'D:/Documents/TEST/RTE/Device/STM32F030R8Tx/STCubeGenerated/MDK-ARM/startup_stm32f030x8.s'ArmClang: error: no input filesassembling startup_stm32f030x8.s...".\Objects\test.axf" - 2 Error(s), 0 Warning(s).Target not created.Build Time Elapsed: 00:00:00
i have a work around it but it still strange why is this happening because a couple a weeks ago it didnt have this issue.
does anybody know how to fix this?
DEVICES:
KEIL 5.3VSTMCUBE: 5.6Vboard: STM32F030R8
Hi,Visibly "D:/Documents/TEST/RTE/Device/STM32F030R8Tx/STCubeGenerated/MDK-ARM/startup_stm32f030x8.s" does not exist ?Be sure of your path and write autorisation... I'm not sur but some directories may be created manually before it.Regards
