USB on LPC1768: Endpoint 1 on device 0 is already used
I'm trying to get USB working on the LPC1768. I was able to successfully build a couple of example projects but haven't managed to get my own working, so am obviously missing something obvious.
In an attempt to narrow down the problem, I've started a blank project, and added the appropriate (i.e. identical to other working projects) libraries through the RTE manager. I get the error
C:\Keil_v5\User\Keil\MDK-Middleware\7.12.0\USB\Include\usbd_config_def_0.h(7043): error: #35: #error directive: Endpoint 1 on Device 0 is already used!
#error Endpoint 1 on Device 0 is already used!
There is no code at all in the blank project, so it's presumably some configuration step I'm missing in the header files. I'm very much a beginner to this stuff. Any insight would be very valuable.
