I always keep getting 2 errors and they are:
a.s(2): error: A1163E: Unknown opcode AREA, , expecting opcode or Macro
a.s(3): error: A1355U: A Label was found which was in no AREA
no matter what I do they are always there. What is the problem?
Example code:
GLOBAL Reset_Handler AREA, mycode, CODE, READONLYReset_Handler
PINSEL0 EQU 0xE002C000IO0BASE EQU 0xE0028000 IO0PIN EQU 0x0IO0SET EQU 0x4IO0DIR EQU 0x8IO0CLR EQU 0xC MASK EQU 0xFF00
MOV r0, #0 LDR r1, =PINSEL0 STR r0, [r1] LDR r1, =IO0BASE MOV r5, #MASK STR r5, [r1, #IO0DIR] Main
STR r5, [r1, #IO0CLR] LDR r4, =0xFFFFDelayOn SUBS r4, r4, #1 BGT DelayOn STR r5, [r1, #IO0SET] LDR r4, =0xFFFFDelayOff SUBS r4, r4, #1 BGT DelayOff B Main stop B stop
END
