I want to take 10000 examples of keil. I can't get char samples [10000] either. Do you have a solution?
My code is below.
#include <stm32f4xx.h>#include <stm32f4xx_rcc.h>#include <stm32f4xx_adc.h>#include <stm32f4xx_gpio.h>
ADC_InitTypeDef ADC_init_structure; //Structure for adc confgurationGPIO_InitTypeDef alper; //Structure for analog input pin float dum1;int ms10Ticks; /* counts 1ms timeTicks */
/*---------------------------------------------------------------------------- SysTick_Handler *----------------------------------------------------------------------------*/void SysTick_Handler(void) { ms10Ticks++; ADC_SoftwareStartConv(ADC1);//ADC1->CR2 |= (1<<30);}
/*---------------------------------------------------------------------------- MAIN function *----------------------------------------------------------------------------*/int main (void) { char huge samples[10000]; int i=0; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD,ENABLE); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOC,ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE); GPIO_StructInit(&alper); alper.GPIO_Pin = GPIO_Pin_5;//The channel 15 is connected to PC5 alper.GPIO_Mode = GPIO_Mode_AN; //The PC5 pin is configured in analog mode alper.GPIO_PuPd = GPIO_PuPd_NOPULL; //We don't need any pull up or pull down GPIO_Init(GPIOC,&alper);//Affecting the port with the initialization structure configuration
//GPIOC->MODER |= (3<<10); // PC5--> ADC.15 input olarak ayarla //GPIOC->PUPDR = 0x00000000; // pull up-down yok
ADC_DeInit(); ADC_init_structure.ADC_DataAlign = ADC_DataAlign_Right;//data converted will be shifted to right ADC_init_structure.ADC_Resolution = ADC_Resolution_12b;//Input voltage is converted into a 12bit number giving a maximum value of 4096 ADC_init_structure.ADC_ContinuousConvMode = DISABLE; //the conversion is continuous, the input data is converted once ADC_init_structure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;//no trigger for conversion ADC_init_structure.ADC_NbrOfConversion = 1; ADC_init_structure.ADC_ScanConvMode = DISABLE;//The scan is configured in one channel ADC_Init(ADC1,&ADC_init_structure);//Initialize ADC with the previous configuration //Enable ADC conversion ADC_Cmd(ADC1,ENABLE); //Select the channel to be read from ADC_RegularChannelConfig(ADC1,ADC_Channel_15,1,ADC_SampleTime_144Cycles);
SystemCoreClockUpdate(); /* Get Core Clock Frequency */ if (SysTick_Config(SystemCoreClock / 10000)) { /* SysTick 10 msec interrupts */ while (1); /* Capture error */ }
while(1) { /* Loop forever */ if(ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC)){//if((ADC1->SR & 0x00000002)){
dum1=(ADC_GetConversionValue(ADC1)); samples[i]=dum1;// BURAYA KODUNU YAZ….örnegi burda aliyor…dum1 içerisine. i++; if(i==10000) i=0; } }
Don't put it on the stack as an auto/local variable.
What is the error/problem here?
Have a clue, explain better.
I can't read the samples values when I start start debug.
wonder if stm32f407vg can store 10000 samples in its memory
Should have enough RAM for 10000 bytes array. Allocate it from the global pool, the stack size in startup.s isn't likely to be sufficient, and honestly you don't really want it there.
Also don't recall "huge" being a valid keyword/attribute
Westonsupermare Pier said:"huge"
Ah, good catch. Let's just say that if the OP is (secretly) doing this on a platform where "huge" is a thing, then the odds that 10 kB will fit into RAM are much lower than they would be for a plain vanilla ARM --- and 10 kB in the stack will basically be out of the question.
