How to get the list of compiler search paths for system headers while compiling using Keil Microvision
E.g.: In case of GCC compilers, Compiler search path could be found by compiling a source file as “compiler.exe –v sourceFile.c –o sourceFile.o”
Is there a similar option for Keil?
Just for hints: We are making use of µVision to run the Keil build using the command: C:/Keil_v5/UV4/UV4.exe -b prj.uvprojx
Open the Project, go to the Options, C/C++ Tab, and then look at the Include Paths
Thanks for the answer, I'm aware of that option! But I wanted to get the compiler search paths that's being used at compile time dynamically so that I can understand the behavior of compiler
