I was playing around with the system_LPC17xx.c and changed the osciallator from "Main oscillator" to "RTC oscillator". The device did not boot, so I set it back to "Main oscillator", but now I get the message "Cannot access memory". Did I break something?
Cannot access Memory (@ 0x00000000, Write, Acc Size: 4 Byte)
I have ULINK2 ME in case that is relevant.
My colleague found the solution. It was possible to flash again by setting the programmers frequency to 5kHz. Afterwards you can flash it normally again.
